2000 Toyota Pickup eratic idle at times
2000 TOYOTA PICKUP
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
BDONEEYE
At times it idles perfect, then at times it almost goes dead.
no codes show up the scanner. We have replaced the fuel preasure regulator, tuned it up[plugs, plug wires, cleaned the throttle body] but still have the same problem. Your response would be appreciated. Thanks......
Aug 9, 2009 at 3:50 PM
Check the Mass airflow meter, idle air control valve, throttle position sensor and clean out the EGR valve
Aug 9, 2009 at 4:06 PM
