[quote:5a8739b11c="blackop555"]for the sake of confusion we will refer the pulley attached to the harmonic balancer and crank shaft as the main pulley.
you say it looks misaligned? is it turning? remember its turning fast and may look like its still.
is that turning just nothing else?
do they turn by hand with the belt on? off? belt tight?[/quote:5a8739b11c]
Thanks for asking. The crankshaft pulley does not turn while the engine is runnig. With all 3 belts still attached with tension on them, I can turn the pulley by hand with the engine off. I can look at the pulley thru the wheel well and see that it is not square or plumb with the block. It angles up(because of the tension on the belts)...Larger gap towards the bottom of the pulley. The truck starts right up,sounds fine, no knocks,leaks,noises,etc. I don`t let it run more than a few seconds(30 ?)
Oct 22, 2008 at 5:00 PM
