1994 Toyota Pickup lost of power
1994 TOYOTA PICKUP
160,000 MILES • 4 CYL • 4WD • MANUAL
CHUCKSTAL
engine loses power on hills
Aug 29, 2010 at 10:01 AM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. could be caused by a clogged fuel filter or one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 30, 2010 at 2:50 AM
