1994 Toyota Pickup gas oder
1994 TOYOTA PICKUP
225,000 MILES • 6 CYL • 4WD • MANUAL
COONHUNTERW2
i have a gas oder coming from under my hood i stoped on asphalt to look for a leek it was dry and also after it sits for a while it is hard to start like it is flooded i also took the cold start bolt out and put a diffrent bolt in without holes to see if that was causing it to flood and it still acked like it was flooded if you could help me i would dearly apreciate it thank u
Aug 14, 2008 at 9:09 PM
Check the vacuum hose going to the fuel pressure regulator if it has gas in it-replace the regualtor-
Aug 17, 2008 at 3:36 AM
