The fuel pump is ran through the EFI circuit opening relay as well as the EFI Main Relay. The EFI circuit opening relay is located behind the right side of the dash, above the ECU. The main relay is located in the fuse / relay block #2 (on the front right corner of engine compartment).
Okay, we have no power to the circuit opening relay, no power to the fuel pump and no power to mass air. The coil is firing, spark plugs firing and fuses are good. What could the problem be? Could it be whats on top the coil? Thanks for the help:)
Mar 12, 2019 at 11:46 AM
(Merged)
CERTIFIED EXPERT
Here is a wiring diagram for the circuit, it looks like the fuseable links in the system are blown if the EFI fuses are all good
Image (Click to enlarge)
(Merged)
2CP-ARCHIVES
MEMBER
Where is the location of my fuel pump relay? I have looked at the fuses under my dash but I don't see that one?
Oct 1, 2019 at 6:15 PM
(Merged)
CERTIFIED EXPERT
Its the circuit opening relay that powers up the fuel pump
Oct 1, 2019 at 6:16 PM
(Merged)
HOOZNEX
MEMBER
1 POST
My truck dies out after being warmed up. I replaced everything (plugs, wires, fuel/air filter, and oil). On another note, is there a fuel pump relay switch and where is it located. Any help will be gladly appreciated. thanks.
Oct 2, 2019 at 10:17 AM
(Merged)
CERTIFIED EXPERT
The circuit opening relay acts as a fuel pump relay see below
