94 Toyota p/u. I keep a messy truck. I did however clean it yesterday and while using the air I could hear the fan. It sounded as though I got a piece of paper trapped up in the box, probably a small bank receipt but it was causing the motor to drag a bit. After returning to the truck, the fan would not work and of course this operates my a/c and my heat.
I figured it was a fuse. I checked all the fuses under the hood and the kick pannel on the drivers side and cannot find a blown fuse.
Does anyone know where this fuse is. There are fuses behind the glove box but I did not want to look. I'm sure it's just a fuse and not the motor as the paper would cause drag which overheated the fan motor (I'm hoping anyway) which blew the fuse. Is this fuse behind the glove box?
Sep 9, 2009 at 2:05 PM
