Runs good at all speeds, idle is erratic when brake is applied. Idle is erratic with slight fuel preasure, then smoothd out at higher rpm.
Jan 19, 2009 at 12:39 PM
CERTIFIED EXPERT
Runs good at all speeds, idle is erratic when brake is applied. Check vacuum hose to the brake booster if its leaking and also the booster itself-could also be the idle air control valve and throttle position sensor
