1993 Toyota Pickup Transmission stick will not shift to sel
1993 TOYOTA PICKUP
177,096 MILES • 6 CYL • 4WD • AUTOMATIC
VICFAUST
Appears that when the driver was stuck in the snow on the farm, the tranny stick jammed, is there a way to quick fix this or is it a major tranny change out?
updated 3/5/09
Thanks for your email, I called our home town Toyota dealer and they were very helpful and adviced to check a couple of items: rear brake lights & knob on 4x4 drive on council.
Mar 4, 2009 at 4:55 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the linkage was broke/bent/knocked out of adjustment.
Raise car, put on stands and inspect linkage on trans. Have someone try to move shifter while you observe the linkage movement.
Mar 4, 2009 at 7:22 AM
