Four cylinder two wheel drive manual 170,000 miles.
Hello, the truck has a 22r-e engine and recently I installed a new head, cam, timing cover, and water pump. The problem is that when the engine is cold it idles very very high, and when the truck warms up the idle will surge. When it is warm, it will surge up a little higher then it should for idle speed, then it will "cut out" and drop back down, and it does this over and over. Applying the brake lowers the idle, but it still surges. Ignition timing and valve timing are spot on. Where should I start? Thank you.
May 6, 2008 at 12:06 PM
