1993 Toyota Pickup Blowing computer fuses
1993 TOYOTA PICKUP
21,200 MILES • 6 CYL • 4WD • AUTOMATIC
AKTRACY
We have a '93 Toyota PU that was running fine. It quit while driving down the road and wouldn't start again. Got it home and found there was no spark. Replaced the coil, truck started and ran for 15 min.then blew a fuse. Everytime I replace the fuse then turn the key to start the truck a 15 amp fuse blows.
What should I check next?
Jan 24, 2008 at 12:58 PM
This is gonna be tough to answer.
Okay-what fuse is it blowing the ignition or the EFI?
Jan 24, 2008 at 1:32 PM
Inbox :: Message
To: rasmataz
Posted: Thu Jan 24, 2008 2:25 pm
Subject: Toyota blowing fuse
It is the EFI fuse blowing.
When you turn key to On it blows right-BTDT
Disconnect the mass airflow meter connector and also remove the circuit opening relay-put another fuse in it and see what happens. If it continues to blow-check the red and white wire going to the computer box pin out +B1 for shorted to ground.
To make things complicated the fuel pump will not come On.
Jan 24, 2008 at 2:43 PM
