Engine Mechanical problem 6 cyl Four Wheel Drive Manual 275000 miles
Clutch was not fully disengaging. Found I had a leaking clutch hydraulics; fluid level was low. Filled and bleed hydrualics. No change. Replaced Main and Slave. Adjusted under dash to max on main cylinder arm. Where is adjuster on oor near slave? I see nothing to adjust on slave. Clutch still does not fully disengage. Have to start car in gear. Can shift when running.
Sep 6, 2010 at 1:46 PM
