1992 Toyota Pickup Brake Lights Not Working
1992 TOYOTA PICKUP
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEMEL77
Help, I am having trouble with my brake lights. The fuse is OK (replaced with new)& replaced brake light switch ( as per local parts store).
The brake lights did work recently including trailer lights. Bulbs are good as I had to replace one because a tail light was not working.
I have no power at the at the brake lights.
Amy thoughts as my wife is getting upset with me and wants to go to a repair shop but unfortunately I am a disabled FF and to stubborn to let her go to a shop. I am not a mechanic but have been doing auto repairs and maintenance for over 40 years and just stuck for the moment.
I am hoping with your help I can avoid a trip to the local repair shop not because I do not want to support them but because I do not have the funds for such an expenditure at this time in my life.
Please HELP!
PS I did go to a website where you pay to get an answer and after explaining that I replaced the fuse, despite is being good, with a new fuse they responded and told me to replace the fuse & their final answer was to run a new wire from the brake light switch ( as I informed them that I replaced the switch) to the tail light, which is not a simple fix. AGAIN, PLEASE HELP, if you can.
Thank you in advance! JJ
Feb 8, 2010 at 2:28 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
First thing to do is prove the power flow through the switch with a test light, if you have power through the switch with the pedal pressed, check for power and earth at the plug into the rear combo light, start here.
mark (mhpautos)
Feb 8, 2010 at 3:53 AM
