My truck is having trouble shifting into 1st 2nd and reverse. the trans and clutch were replaced about three years ago, so i don't think that is the issue. I've taken it to a mechanic and he said he thought it was the hydraulics... so he replaced the master and slave cylinder. he then said the clutch was stuck against the flywheel, so i gave hime the go ahead to take the trans out and release and fix that and then see if the clutch needed to be replaced as well, the clutch didn't so that is good. BUT NOW he has found that the clutch and brake pedal bracket is cracked and flexing and he says the flexing is whats keeping the clutch from opening up all the way. does this sound legitimate or am i being had?
Jun 3, 2009 at 10:04 PM
