1991 Toyota Pickup no spark or gas to motor
1991 TOYOTA PICKUP
236,000 MILES • 6 CYL • 4WD • MANUAL
BLUEJAY30
I remover the air chamber on my truck toreplace the valve cover gaskets and then put everything back the way it was but now engine wont start, theres no spark and no gas getting to the motor
Apr 20, 2010 at 10:50 PM
Check all the fuses if okay double check the airflow meter and distributor connection
Apr 21, 2010 at 12:31 PM
BLUEJAY30
i fixed it i guess one little wire came apart at the cold start above the air filter and if that does work it wont give the engine the go ahead to give gas and spark
Apr 22, 2010 at 1:25 AM
