1991 Toyota Pickup EGR valve
1991 TOYOTA PICKUP
178,000 MILES • 4 CYL • 4WD • MANUAL
JACOBRECORD22
How do you tell if a EGR valve is clogged up? and how do you clean it out if it is clogged up?
Mar 11, 2010 at 9:55 AM
There are a couple ways to check this, but the first way is to check for codes.
Here is a guide that will help with this:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Also, here is a guide that will help with testing the valve itself which contains really good info:
https://youtu.be/DqUCbbKdWf4
However, the definitive way is to use the testing that we are attaching below.
Please run through this info and let me know what you find. Thanks
May 4, 2022 at 6:32 PM
