I have put a new clutch, pilot bearing, throw out bearing, clutch fork, slave cylinder, and clutch master cylinder. I still could not get the trans. to shift. tore the dash apart and found the bracket the brake and clutch pedal are on, was broke. Got it welded and reinstalled. Bleed the system AGAIN!!! Still can not get the clutch to disengage enough to shift. Is there a special way to bleed the clutch system on a Toyota to get all the air out?
HELP!!!!!!!
HELP!!!!!!!
May 20, 2008 at 6:03 PM
