1990 Toyota Truck
1990 TOYOTA PICKUP
GEOBJ
I have the 2.4 litre engine, with around 166k. The speedometer has stopped working, so I disconnected it from the transmission and spun the shaft, and the speedometer registers. Is the cable splines worn, or is ther something else in the transmission?
Jun 28, 2006 at 8:27 AM
put it back in make sure its align properly and push it all the way in before you tighten the bolt and retry
Jun 28, 2006 at 7:48 PM
GEOBJ
Have done that several times now, always rechecking the speedo cable, figured its the weak link. Is the driven gear anything that can wear out?
Jun 29, 2006 at 7:54 AM
