1990 Toyota Pickup Fuel System
1990 TOYOTA PICKUP
94,000 MILES • 6 CYL • 4WD • MANUAL
FREEMANATLAST
I recently did a repair on my truck where I had to replace the head gaskets and have the heads resurfaced. I put everything back together and noticed that I had gas coming from my tail pipe. I checked the spark plugs and found that one of them was soaked. I got the injector tested and had to replace it. at the same time I replaced all the seals on all the injectors. I then put everything back together and still have gas coming from the tail pipe. What should I do next and what are the possible problems?
Mar 9, 2010 at 1:02 AM
Pull the vacuum hose from the fuel pressure regulator and check if there's fuel in the hose or regulator if so replace the regulator
Mar 9, 2010 at 4:58 AM
