1990 Toyota Pickup cold fast idle
1990 TOYOTA PICKUP
97,000 MILES • 6 CYL • 4WD • MANUAL
AOYAGI
Ever since a valve and timing belt repair by a shop the cold start has a very fast idle. I tried adjusting it with the large screw head on the throttle body but it affects the idle rpm. Is this cold start rpm computor controlled? Are there any adjustments I can do? Thanks Tom in Hawaii
May 13, 2008 at 12:53 PM
BLACKOP555
  • 10,386 POSTS
how fast do you consider high?
it is controled by the ICM which is controled by signals from the computer and coolant temp sensor.
May 13, 2008 at 4:26 PM
