1989 Toyota Pickup loss of antifreeze and heater won't heat
1989 TOYOTA PICKUP
123,000 MILES • 4 CYL • 4WD • MANUAL
ROD HOFFMAN
I replaced the radiator as it was leaking. My driving was for only a short distance so I never knew the truck was overheating. On a longer trip of about 10 miles, I noticed the temp guage rising quickly. I pulled over and let the engine cool for awhile. I then checked to see if there was any antifreeze. There was not, so I checked the oil stick and found it over filled with with a milky substance. This I assumed was antifreeze inside the engine. One mechanic said it could be a head gasket, or possibly a cracked block or even worse, but one couldn't tell without taking the head off. Another mechanic said he has seen this a few times with an r22 engine with 100,000 to 150,000 miles. His best guess is that the timing gear has probably worn through the plastic watershield(????) which is allowing antifreese into the engine. The engine is not running rough and is not making any noise. What do you think?? Any suggestions??
Jan 28, 2008 at 4:05 PM
BLACKOP555
  • 10,386 POSTS
easiest way to check a headgasket or cracked block is to perform a cylinder compression test, the lowest shoudl be no more then 25% less then the highest, if one is then chances are its a bad head gasket, cracked block, or cracked/warped head.
Jan 28, 2008 at 4:49 PM
