1989 Toyota Pickup clutch
1989 TOYOTA PICKUP
210,000 MILES • 6 CYL • 2WD • MANUAL
SKYLER
  • 4 POSTS
i was driving my truck an when i pushed in on my clutch pedal it made a loud sound an then felt like it didnt want to go into gear. i got it home an couldnt get it in to gear when it was started but i could when the truck was off. my clutch wont disengage an i droped my tranny an everything looks fine. i replaced my whole clutch kit 6 months ago an i just replaced my slave cylynder an it still will not go into gear when started. forgot to say that when i put it in gear when the truck is off, then start it an let off the brake an clutch it starts to drive its self. any ideas?
thank you for your help in advance
Dec 17, 2007 at 7:13 AM
Your clutch is not releasing-double check the clutch master cylinder and slave/servo and also bleed it and adjust the clutch free play and pedal height.
Dec 18, 2007 at 4:27 PM
SKYLER
  • 4 POSTS
I got all that done, but when i went on my test drive there was a loud rattling/grinding sound an it seemed to get worse when i was driving. what could cause it?
Dec 18, 2007 at 6:23 PM
Sorry to say-but you are going back in the clutch assembly -rattling/grinding could be the pressure plate/release bearing/disc.
Dec 18, 2007 at 9:21 PM
SKYLER
  • 4 POSTS
well thank u for your help an time an i will check it all out again. could it be anything to do with my push rod being to far in or out?
Dec 18, 2007 at 10:05 PM
