1989 Toyota Pickup alternator/ charge system/ shortage ????
1989 TOYOTA PICKUP
GINAROX
Electrical problem
1989 Toyota Pickup 4 cyl Two Wheel Drive Manual
it's not the alternator. we changed it and now it's charge is reading below the norm when started. we think it's a shortage or wire problem. the problem is what or where can we check? we checked the fuse under the hood and in under the dash. can you give me any and all info on this matter. going nuts..
thank you
Aug 6, 2008 at 9:01 PM
KHLOW2008
  • 41,814 POSTS
Hi ginarox,
If the charging voltage at alternator main mast and battery terminals are below 13.5, the alternator is bad or the beltings are loose, the crankshaft pulley is faulty.
Aug 24, 2008 at 1:27 PM
