Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Pickup
Climate Control
Air Conditioner
Compressor
Clutch
Replace/Remove
1989 Toyota Pickup A/C clutch removal
1989 TOYOTA PICKUP
26,000 MILES • 6 CYL • 2WD • MANUAL
MICHAELHYDE
MEMBER
1 POST
FOLLOW
How do I remove the clutch from my A/C compressor? I have the radiator removed for timing belt replacement.
Mar 30, 2009 at 8:19 PM
JAMES W.
CERTIFIED EXPERT
There is a 13mm nut in the clutch hub center that holds it to the shaft. But, it takes a special puller to remove the clutch hub from the shaft.
Mar 30, 2009 at 10:35 PM
