turn lights are not working
1987 TOYOTA PICKUP
200,000 MILES • 4 CYL • 4WD • MANUAL
ERAMOS
  • 4 POSTS
my turn lights and emergency lights are not working anymore. they were a couple days ago.[img:ee2a2a07fe]http://www.2carpros.com/forum/automotive_pictures/367004_3ka3mb3o7ZZZZZZZZZ95t5f852a07f97517bf_1.jpg[/img:ee2a2a07fe]
Jun 9, 2009 at 4:42 PM
SERVICE WRITER
  • 9,123 POSTS
Not working meaning not flashing or not lighting at all?
Jun 9, 2009 at 5:39 PM
ERAMOS
  • 4 POSTS
emergency lights and turn signals are not working at all, they were working good last week though.
Jun 9, 2009 at 7:56 PM
ERAMOS
  • 4 POSTS
head lights are ok, it is only the emergency and turn signals the one not working (not even on).
Jun 9, 2009 at 8:10 PM
SERVICE WRITER
  • 9,123 POSTS
Okay...So they do nothing when they are turned on.
Check the fuse first.
IF good, Rapidly move the hazard switch and see if they react. That can flush out a bad switch sometimes.
Jun 9, 2009 at 8:44 PM
ERAMOS
  • 4 POSTS
I did check all fuses, light bulbs every thing looks okay, but I haven't done that move from fuse to hazard switch...what else could be after that if still not working?
Thank you for your help!
Jun 9, 2009 at 8:53 PM
SERVICE WRITER
  • 9,123 POSTS
What I meant was push in the hazard switch in and out rapidly. ANyways, the common denominator here is the combination switch. IF power is going to it but not coming out, you'll need the combination switch that incorporates both the hazard and turn signal switchs into one component.
https://www.2carpros.com/forum/automotive_pictures/30961_toystco_1.jpg
Jun 10, 2009 at 5:47 AM
ELREDEYE
I had the same problem on my '87. I replaced the flasher right below the fuse box.
Jun 30, 2009 at 7:44 PM
