1987 Toyota Pickup Horn
1987 TOYOTA PICKUP
222,000 MILES • 4 CYL • 2WD • MANUAL
MARK F.
My 1987 Toy. P/up has a horn that simply won't work. I've checked the connection at the horn, it's fine. I replaced the center peice on the steering wheel with a new dealer part, still nothing! Just before it went altogether it worked when I would turn the wheel half way around, and then it was only a weak sounding horn. I beleive the problem is somewhere in the steering column itself. My repair book doesn't have any skamatics to help me. Is there a way of "hot wiring" the horn? Or is this a problem for a certified repair shop?
Respectfully
M.F.
Dec 31, 2007 at 2:27 PM
MERLIN2021
  • 17,250 POSTS
Do you have a test light? or voltmeter? Unplug the horn, use test light, have someone blow horn, does the test light light? If yes you need a new horn, if not check the relay, and fuse.
Dec 31, 2007 at 2:30 PM
