1987 Toyota Pickup 2008 stock tacoma rims on a 1987 pick up
1987 TOYOTA PICKUP
324,000 MILES • 4 CYL • 2WD • MANUAL
INSPECTIONEDDIE
i have a stock 1987 toyota pick up with stock rims on it ,they came with from 1987. i got a good deal on a set of 2008 stock tacoma rims with tires in good condition. the bolt pattern lines up but still does not seat right. is there any adapters or anything i can do? the rims look reall cool on my truck- so i kinda would like to try to get them on before i put them on criagslist.
thanks
Jul 2, 2009 at 10:03 PM
2CARPRO JACK
  • 11,533 POSTS
Most likely the center flange is different.You could possibly use wheel spacers, but that will make it drive weird when the tires stick out, and it will most likely rub the fenders.I have seen people grind out the center of the wheel a little to clear the hub, I dont advise it but I have seen it done.
Jul 3, 2009 at 8:48 AM
