Starter Relay Location Please
1986 TOYOTA PICKUP
BENNYSTEWA
I need to know the actual location of the starter relay for this particular model vehicle. It is not specific in the vehicle manual I have. Can you clarify exactly where it is located?
Mar 8, 2010 at 1:07 PM
DOCFIXIT
  • 18,828 POSTS
The starter relay is on the front right side of the fender under the hood here is a guide to help you test it with the location in a diagrams below.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers,
Mar 8, 2010 at 1:27 PM
WCROSBY3
when i turn the key, it clicks and does not turn over. i have replaced battery and connections are good. checked grounds, new starter, distributor cap. truck runs good when pop starting down a hill. cant get it to crank with key. Where is the starter relay located?
Oct 22, 2018 at 9:19 PM (Merged)
You don't have a starter relay- check and test the neutral start switch and the ignition switch
MCCORKLE1210
Where is the starter relay located on a 1987 toyota pickup 4X4 2.4L and what does it look like?
Oct 22, 2018 at 9:20 PM (Merged)
The starter relay is located under the hood on the passenger's side. Here is a guide to help you test it.
Cheers
RUMPLEDFOESKIN
  • 6 POSTS
pickup has 235,000 miles.at about 150,000 miles starter relay started clicking very loud. then it
sporadically started not engaging starter., but still clicks. if i leave it sit anywhere from an hour to all night, it will engage starter . so i changed starter relay. new relay clicked from beginning. now doe`s same as old relay, periodically will not engage starter. what now
MLDANIELS2000
  • 227 POSTS
Sounds like the bendix in the starter is not being thrown out to engage the flywheel. Try changing starter. Some parts store can test it if you can get it off. Check engine ground strap as well.
RUMPLEDFOESKIN
  • 6 POSTS
starter is new, so is battery, this only happens once in a while . if it happened on a regular basis , i think you would be right.
RUMPLEDFOESKIN
  • 6 POSTS
havent thought of engine ground. will try that. starter gets a lot of leaking oil on it, to
HEBUS
  • 4 POSTS
Have been through 3 startes in two years - just ad another replaced today....after driving three places I turned the key and NOTHING...I could not believe it - so just like all the others, popped the hood and tapped the starter and it started just always. The issues has happened with each previous starter and occasionally this occurs...it had been occuring with more frequency so I had it changed out with a new/rebuilt unit. Something is really goofy - why not starting and whey does it always start after rapping on the starter. Had to believe it's really a starter issue. Seems to get worse with hotter weather - Please advise.
You sure the battery terminal and starter solenoid wire are in good shape-Its weird though banging it and it works which points to a starter problem-
HEBUS
  • 4 POSTS
As I mentioned - starter is just out of the box....same with all the others....I just can't figure why when striking the starter is always works.
Remove the black wire or white and black wire from the solenoid not the battery wire-have helper hold key at cranking position and check for power
HEBUS
  • 4 POSTS
After the Charger game...LOL
Enjoy the game, I'll see you in 2wks-bye
