1986 Toyota Pickup Runs too hot
1986 TOYOTA PICKUP
246,000 MILES • 4 CYL • 2WD • MANUAL
JONNYBOY18
  • 5 POSTS
It has radiator fluid in it but I live in the middle of Texas and it just seems to not be able to stand the heat. The temperature just steadily rises and after about 30mins of driving it is approaching the red line on the thermostat. Would maybe getting a newer or a bigger radiator help to alleviate this problem?
Aug 26, 2010 at 7:29 PM
Try replacing the thermostat and see what happens
Aug 26, 2010 at 7:33 PM
JONNYBOY18
  • 5 POSTS
So then you are saying that I may be getting a false reading?
Aug 27, 2010 at 8:45 AM
The thermostat controls the engine temperature, the engine temperature gauge sender or the coolant temperature sensor reads it and then to the temperature gauge
Aug 27, 2010 at 2:23 PM
JONNYBOY18
  • 5 POSTS
So the thermostat has already been removed so if I put one on it then it will just heat up even quicker. I talked to the guy I bought it from and he said that the water pump is new. So I am first going to replace the stock radiator and then If that doesn't help enough then I am going to replace the fan clutch. Though I may think about installing that thermostat once winter comes around.
Aug 29, 2010 at 8:57 AM
Get the cooling system block and pressure tested.
Aug 29, 2010 at 5:00 PM
