My trusty toyota p/u died the other day with no signs of any problems. I have checked for spark and there is none. I replaced the cap, rotor and wires and still no spark. I tested the coil and its resistance is within the limits. I replaced the coil for good measure. with the cap off the rotor is turning and the motor has good compression. I used a volt meter on the two wire harness coming from the distributor and voltage was being sent to the coil. What do i look for now since I still have no spark?
Apr 27, 2008 at 6:21 PM
