1986 Toyota Pickup lots of gas in oil
1986 TOYOTA PICKUP
RATRODBYT
Engine Mechanical problem
1986 Toyota Pickup 4 cyl Two Wheel Drive 140000 miles
I have put a new carb and pump on and changed the oil and it still getting alot of gas in the oil I start it and in no time It wont start and their is a lot of gas in oil?
Jul 1, 2010 at 2:20 PM
Look down the carb's throat do you see fuel dribbling all over if so check the needle valve if its stuck open or float has a pin hole-also check the fuel pump-diaphragm could be ruptured
Jul 1, 2010 at 5:42 PM
