1986 Toyota Pickup hazzard lights
1986 TOYOTA PICKUP
183,000 MILES • 4 CYL • 2WD • AUTOMATIC
NICKBIGSLICK
i bought this 1986 toyota pu used and everything worked but the hazzard lights and radio someone had wired a secondary push button horn but it had a hot wire straight from the battery to the horn and when you turned the hazzards on no flashing but horn blowed i removed the hot wire now now flashing no horn no radio any ideas
Apr 4, 2008 at 3:26 PM
If its individually controlled circuit-check the fuse to both then comeback if needed.
Apr 4, 2008 at 3:35 PM
