Engine Cooling problem
1985 Toyota Pickup Four Wheel Drive Manual
Due to a crack in the head, we replaced the head. We also replaced the water pump, thermostat, timing chain and timing chain guides. We drained the oil, bled the clutch and removed the water out of the exhaust. Now when we let the truck warm up, the gauge shows it's overheating but you can remove the radiator cap and the water is cold and there is no pressure built up. Everything else seems to be ok.
Feb 25, 2010 at 5:43 PM
