1985 Toyota Pickup pilot bearing
1985 TOYOTA PICKUP
JJBONZ
Transmission problem
1985 Toyota Pickup 4 cyl Two Wheel Drive Manual
do you have to take out trans to check or remove pilot bearing
Jan 15, 2009 at 7:15 PM
KHLOW2008
  • 41,814 POSTS
Hi jjbonz,
Yes, the pilot bearing embedded in the crankshaft and the transmission clutch shaft sits on it.
If the pilot bearing is bad, you would get a grinding noise when clutch is depressed with gears engaged and vehicle running.
Gear shifting would tend to crash if the bearing is seized or partially seized.
Jan 18, 2009 at 12:48 PM
