1984 Toyota Pickup Mechanical
1984 TOYOTA PICKUP
202 MILES • 4 CYL • 4WD • MANUAL
JFAUTH
My 1984 Toyota pickup is having brake problems when i brake it goes to the left pretty quick and will not stop after bleeding the lines properly and adding the required DOT5 fluid (autozone) do you guys have anyother ideas other then getting it realigned which les Schwab did last fall
Jun 14, 2010 at 11:33 PM
MHPAUTOS
  • 31,937 POSTS
Sounds as if one of the calipers are faulty or you have a part blocked brake hose, check these out first.
mark (mhpautos)
Jun 15, 2010 at 1:02 AM
