When starting from a dead stop in 1st it seems my clutch will grab so much that it will almost stall my engine unless I let off the gas completely as I ease out the clutch petal at just the right time, the truck will have to be rolling just a little at this point, then the truck lurches forward and rattle real hard. It seems to drive fine in the others gears once the cars is moving and dose not see to suffer from a slipping clutch, or jerking motions, and the transmission seems to be fine. I have plenty of power through the gears. I've driven lots of manual cars and this is the first where I have to let off the gas completely as I let off the clutch. It seems really sensitive. If I where to treat it like a normal manual transmission, with conservative treatment, the engine rattle violently and will stall when putting it into gear.
Oct 12, 2008 at 3:12 PM
