Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Pickup
Engine
Symptoms
Compression
1983 Toyota Pickup willnot start low compression
1983 TOYOTA PICKUP
20,100 MILES • 4 CYL • 2WD • MANUAL
SLIGHT50
MEMBER
1 POST
FOLLOW
my truck got hot and stalled after it cooled down it will crank but not start.
Jan 21, 2008 at 5:18 AM
CERTIFIED EXPERT
Spray carb cleaner in the Carb or Throttle Body -if it fires up-you have a fuel problem if not its an ignition.
Disconnect a sparkplug wire and ground it to the engine and have helper crank engine over-do you have a snapping blue spark?
Jan 22, 2008 at 12:42 PM
