1983 Toyota Pickup cant get started
1983 TOYOTA PICKUP
JESWADE
  • 4 POSTS
Engine problem
1983 Toyota Pickup 4 cyl Four Wheel Drive Manual ???? miles
i cant seem to get the truck to start.. when i turn the key i get nothing no noise from the starter even the heater fan dont work .. nothing inside the cab works.. my headlights do work...its been running fine till his morning..
Jan 15, 2008 at 4:57 PM
Get yourself a test light and start checking all the fusible links before and after it for power this is where you start. When it all checks out inspect the miniature fuses all of them. Fusible links and fuses checks out-test out the igntion switch and report back your findings so that I can continue to assist
Jan 17, 2008 at 7:24 PM
JESWADE
  • 4 POSTS
i did everything seems to have been ok.. friend came by and found a bad wire.. replaced it and it runs... thank for the help...
Jan 21, 2008 at 11:00 AM
You're welcome and do drop in again and invite friends over.
Jan 21, 2008 at 11:04 AM
