I replaced the master cylinder on this pickup because there was an obvious internal leak. When I went to bleed the brakes everything went as normal bleeding the rear right first then rear left. When I was done, the pedal was rock hard with only 2 inches of play and no squish, making it impossible to bleed the fronts. Has anyone heard of this problem? I am suspecting a problem with the new master cylinder, (it's new not reman). The truck has drum rears, and disc fronts. Any thoughts on the subject would be greatly appreciated. Thanks.
May 25, 2008 at 5:12 PM
