1978 Toyota Pickup coil and plugs
1978 TOYOTA PICKUP
APREYJR
Electrical problem
1978 Toyota Pickup 4 cyl Two Wheel Drive Manual
i have power going to the coil, but pick-up truck engine, while it cranks will not start. I removed the coil wire from the dustributor, cranked the engine, but not arcing from the coil distributor wire. Besides the obvious n/g coil, is there any way to test the coil while still in the engine, or does it have to be removed to test.
thank you
andy reynolds jr.
Jul 15, 2008 at 3:30 PM
Dunno the resistances for the coil -remove both positive and negative wire from coil-measure the primary side by reading the positive and negative terminals of the coil should read less than 1 ohm. Secondary readings measure the negative terminal and the center coil tower readings should be less than 18K ohms
Jul 15, 2008 at 3:39 PM
