Yes, my alternotor belt broke off last night on my way home from work. If you can tell me how to take off the outer belt, so that I can put on my new alternator belt, I would be greatful. There is no tension slide to loosen outer belts, like the slide bracket on the Alternator to use to loosen and tighten the belt. All I saw was the Bolt to the Air compressor that is fixed and not on a tension slide bracket. I am wondering how I can take off the outer belt. I have no idea exactly what to do, since there is no bracket, can you help me out? Thank you. SPC Louis Berry.
Jan 21, 2008 at 4:51 PM
