1994 Toyota Paseo power to starter, bleenkers, radio, fan.
1994 TOYOTA PASEO
20,000 MILES • 4 CYL • FWD • AUTOMATIC
GLEN462005
have power to head lights, interior lights, dash lights.
battery is fine. accidentally touched power wire at the alt.on the body changing water pump. what a bitch that was. got that done now wont start. HELP PLEASE!
Jun 30, 2010 at 7:54 PM
Hi glen462005, Welcome to 2carpros and TY for th donation.
Is it cranking over and will not start or just won't crank at all/nothing when you turn the key to starting position. Let me know
Jun 30, 2010 at 10:54 PM
GLEN462005
it has a lite click sound on the riight side. does not crank at all.. like i said- no power to starter, bleenkers, fan, and radio. checked fuses. all good.
Jun 30, 2010 at 11:17 PM
Check and test the alternator fuse 10O AMP AND AM1 50amp, AM2 fuse 15amp and Ign fuse 7.5amp. If all okay
Check the black and red battery cable on the starter for power -you should have it also have helper hold key in starting position and check for power on the plain black on the starter solenoid -you should have it, if not check and test the starter relay, park/neutral position switch and ignition switch.
Jul 1, 2010 at 3:33 PM
