I just installed a used engine and my original transmission with a new clutch/flywheel set. I got the engine to run fine except for a ticking sound. It only happens under acceleration. It sounds like an exhaust leak on an air cooled VW Beetle. The sound only happens when I press the gas pedal. It goes away while cruising. I can't make the sound happen while in the driveway. I've jacked up the car and put it in gear, but it won't make the sound. I also installed an OBX header with a new FelPro, dual layer, steel gasket.
Sep 21, 2010 at 8:43 PM
