My Sister's 1993 Toyota Paseo, started running hot. I discovered that the radiator cooling fan will come on if you turn on the A/C. But without the A/C on, the fan will not cycle on and off. Which causes the engine to overheat.
I have replaced the relay switch in the fuse block, checked all the fuses, Replaced the temperature sensor that powers the temp gauge. All with no luck. With the engine running, and the A/C turned off, the cooling fan will not come on.
What am I missing?
What am I missing?
Apr 26, 2010 at 8:12 PM
