Toyota ...helpme....
TOYOTA
AURORA2B
Ok, So like the great gal that I am I dont do the whole maintanance thing on my car....I think this time I really screwed up. My car is a 2003 Toyota Solara V6 with 72K milies or so. its is an automatic.
I started the car and went down the street....then it died. the check engine and oil light and battery light came on, but the radio stil worked, I had a full tank and no sputtering happenned and there had been no noises or signs of any car problems . so I waited and started it again it started and then died a couple miles later.
When I got home I checked the fuilds and the oil is a bit low, there was no coolant. and there was some corrosion on the battery.
Do I need to take it in to the mechanic or is it possible that I just need to fill the fluids.......
help
May 13, 2007 at 3:36 PM
[quote:ed9194b351="aurora2b"]Ok, So like the great gal that I am I dont do the whole maintanance thing on my car....I think this time I really screwed up. My car is a 2003 Toyota Solara V6 with 72K milies or so. its is an automatic.
help[/quote:ed9194b351]
Fill the fluids and take it in and have them check the fuel pressure to identify a failing fuel pump for a start
Your problem could also be in the ignition system
HTH Good Luck
May 13, 2007 at 7:41 PM
CYRIL PINAS
Torque seguence of cilinderheadbolts
Torque specifications of:
cilinderheadbolts;
connectingrodnuts;
mainbearingbolts;
damperpulleybolt and
flywheel/flexplatebolts.
Thanks so far.
Aug 14, 2007 at 4:27 AM
[quote="cyril pinas"]Torque seguence of cilinderheadbolts: work from center out
cilinderheadbolts; 84-97lbs
connectingrodnuts;35-54lbs
mainbearingbolts; no.1-3 91-108lbs no.4 76-94lbs
damperpulleybolt : 116-144lbs
flywheel/flexplatebolts:58-79
Hope this helps you-Good Luck
Aug 14, 2007 at 4:51 AM
