[quote:1125f2591e="tonyx05"]rasmataz what would i do 1st, change the fuel pump? by the way how do i check the fuel pressure my self, i don't wanna take to any mechanic any-more, the're driving me nuts. please help thanxxxxxxxx[/quote:1125f2591e]
Worrry about the F/pressure later. Test the throttle position and MAP sensor by following the book procedures.
RAV4 TPS checks
RAV4,
(1)Fully Closed VTA & E 2200-5700 ohms
Fully Open VTA & E 22000-10,200ohms
VC & E 22500-5900ohms
(1)Apply vacuum to throttle opener before checking TP sensor.
In the book find the illustration of the throttle opener and do below.
THROTTLE OPENER ADJUSTMENT
RAV4
Start engine and warm engine to normal operating temperature. Ensure idle speed is within specification.
See 4-CYLINDER IDLE SPEED under IDLE SPEED & MIXTURE.
With engine idling, disconnect and plug vacuum hose at throttle opener. Increase engine speed to 2500 RPM. Release throttle and note engine speed.
Engine speed should be 1300-1500 RPM with electric cooling fan off.
If engine speed is not within specification, loosen lock nut (if equipped) and rotate throttle opener adjusting screw until correct engine speed is obtained. Tighten lock nut (if equipped). Reinstall vacuum hose on throttle opener.
You might have a dead spot on the TPS or a problem with the MAP sensor
Do you have any OBD2 code/s
Jul 27, 2007 at 6:32 AM
