pressurized oil pan
TOYOTA
SPOT0112
i have a 1989 toyota corona E.ST170-AEPNM running the 4S-FI 1838cc motor the car is pressurizing the sump and blowing out the oil it does not appear to have a pcv valve as such can anyone shed some light on this please :evil:
Apr 14, 2007 at 8:47 PM
[quote:ff2e79cf13="spot0112"]i have a 1989 toyota corona E.ST170-AEPNM running the 4S-FI 1838cc motor the car is pressurizing the sump and blowing out the oil it does not appear to have a pcv valve as such can anyone shed some light on this please :evil:[/quote:ff2e79cf13]
Better recheck again-Nowadays we use Type 4 closed ventilation system-did you check on top of the valve cover-sometimes you have to pry it off and end up braking it. and while your on it-check the filter and hoses in the air housing.
Your problem is, its flowing backwards creating the pressure and can blow out oil seals.
Apr 15, 2007 at 12:58 AM
