Other Toyota Models Toyota L engine
TOYOTA
LITTLEACE
  • 4 POSTS
Noises problem
Other Toyota Models 4 cyl Two Wheel Drive Manual
I am hearing a sound similar to a fuel knock. In case I am right how can I remove the knock at idle speed?
Sep 29, 2010 at 7:22 AM
If its a ticking and tapping type noises could be your valve lifters
Sep 29, 2010 at 7:26 AM
MHPAUTOS
  • 31,937 POSTS
Are you sure it is not a bearing noise, have you checked the oil pressure, i will need the exact engine code as well.
Mark (mhpautos)
Sep 29, 2010 at 7:27 AM
LITTLEACE
  • 4 POSTS
I'm not privy with the engine code. I'm sure it's not a bearing noise hearing it from the top. Further besides that noise the engine is running smoothly. No vibrations.
Sep 29, 2010 at 7:31 AM
When was the last oil change? Might just work if you do an oil/filter change, also consider engine flush-Its advisible to check the oil pressure could be the oil pump getting tired or a blockage somewhere -such as the pick-up screen and oil galleries and worn out engine bearings causing the oil pressure to be low and not getting all the way up there to the valvetrain causing them lifters to be sounding off-
Sep 29, 2010 at 7:39 AM
LITTLEACE
  • 4 POSTS
This engine has no lifter. It is equipped with rocker arm.
The engine is newly overhauled.Though I did not replace the camshaft bearings finding it unnecessary.
In my analogy it is a fuel knock and not a valve noise.
Sep 29, 2010 at 8:08 AM
MHPAUTOS
  • 31,937 POSTS
I need the engine model.
mark (mhpautos)
Sep 29, 2010 at 8:16 AM
LITTLEACE
  • 4 POSTS
I guess there is only one Toyota L; next models are 2L etc.
Can you please simply give me an idea on how I can deal with the fuel knock? I'm not familiar with it's injector and pump.
Further, this engine is installed in a wrangler jeep and I suspect the gas tank structure as one of the culprits.
Sep 29, 2010 at 8:23 AM
MHPAUTOS
  • 31,937 POSTS
i can't help you with out the engine code, it is printed on the compliance plate in the engine bay.
mark (mhpautos)
Sep 29, 2010 at 5:43 PM
