2004 Other Toyota Models Rear window
2004 TOYOTA
TOM MCGOWAN
Electrical problem
2004 Other Toyota Models V8 Four Wheel Drive Automatic Sequoa miles
My rear window will not operate either by the switch in on the dash or by using the key. I hear a click when I try with the key but nothing happens. All other windows are working properly. Could this be the motor? If so how would I access the motor or test to make sure it's the motor.
Appreciate you help!!
Tom Mc
Aug 6, 2008 at 9:26 AM
KHLOW2008
  • 41,814 POSTS
Hi Tom,
To access the motor connectors, you need to remove the door trims.
Remove any visible screws and look for hidden ones under caps. Pull panel outwards off the locking clips.
Aug 18, 2008 at 9:38 AM
