1999 Other Toyota Models replacing broken axle mount
1999 TOYOTA
82,356 MILES • 4 CYL • 2WD • MANUAL
WDTOUCHBERRY
I'm not sure what the part is to ask the right question. Behind the front left brake is where the sheered-off part is. It is connected with two bolts to the lower arm and a center pivot joint to the steering arm. How do you remove the ball joint on the steering arm (connected via a threaded arm) that goes into the boot?
May 4, 2008 at 1:58 PM
MASTERTECHTIM
  • 4,750 POSTS
i think your talking about a outer tie rod end that is broken. you have the bolt off but you cant get it out of the spindle, am i right so far? get a big hammer and hit the part that it goes into, thios will shock it and it will pop out.
May 4, 2008 at 2:15 PM
WDTOUCHBERRY
Thanks Tim,
I'm trying to get a quick pic to you so that we are talking thee same part. If so I'll gladly donate for your efforts.
Dwight
May 4, 2008 at 2:51 PM
MASTERTECHTIM
  • 4,750 POSTS
OK JUST PUT THE PICTURE IN THE UPLOAD PICTURE BOX IF YOU CAN
May 4, 2008 at 2:55 PM
