1993 Other Toyota Models hi i nead a answer
1993 TOYOTA
GORDYTO
Transmission problem
1993 Other Toyota Models Four Wheel Drive
i am working on a toyota t100 and whe change the clutch and whe ave a pedal that is realy loose and it dont whant to engage to make it chift up or down so if you can get me and anwer i will be realy good and feal realy good
Oct 31, 2008 at 1:59 PM
MASTERTECHTIM
  • 4,750 POSTS
did you bleed the hydraulic clutch? there should be ableeder screw on the clutch slave cylinder, make sure the clutch master is full of fluid and then open the bleeder and see if air escapes, if it does then close the bleeder and you should be all set
Oct 31, 2008 at 2:16 PM
